CaptGoldenEars
....to run a compressor pedal (Dunlop Super Comp) through the effects loop of a tube amp? Thanks in advance.
No harm to the amp, could harm the pedal depending on the level your fx loop runs.......but most pedals can take some abuse.
But it most definitely will harm the sound! I would think you would not be able to use very much compression at all before the tone would be seriously squashed!
Why are you wanting to do this? Experiment for 10 minutes and see what it does.....
Compressors belong in the front of the signal chain and should go to the input of the amp - not the loop....
The compressor pedal is made to tame the spikes in your guitar signal, not made for your amps preamp signal. You really are negating a lot of the amps value by compressing in the loop. Try compressing up front and using a clean boost in the loop instead.
