miroslav
Cosmic Cowboy
Do you mix there...or just contemplate?
No, you actually don't. That's the fallacy. A center-panned track still appears in the center and one panned 10% left or right still appears to be 10% left or right, etc. There is no hole anywhere.If you spread speakers 8' apart and sit up close, like say only 2' away from their L-----R line...you end up with a hole in the center of your image.
So I just stood up now and grabbed the farther of the speakers and placed it on the printer (no I cant leave it there), creating a 6' triangle - and the hole I didn't know was there disappeared, giving a fuller sound if that makes sense.
There is no way in the world that I can describe this - except to say that it works. I don't know why it works but it changed the sound.
Don't you dare ever disagree with SSG.I guess then...95% of the pro studios can't be wrong.
That has been my biggest point...that I tried a lot of positions, angles, distances...and YES, it all makes a difference, and YES there are some ranges/positions that DO sound better.
Maybe we can now put this thread topic to rest....![]()
Is it conventional to have them closer? Yes.Would I prefer to have a tighter angle than we have at Product? Yes. Is there anything special or magical about 60°? Absolutely not. And I dare you to find any actual treatise on how stereophony actually works that says that 60° - even give or take 15%, or 30% - is required for consturction of the image. You won't , because it's not. It doessn't matter how many people claim otherwise, there's no opinion that overrules the actual mathematics and physics of it. Mother nature's opinion trumps all.
So like...in one paragraph you basically agree about closer placement and tighter angles...and then turn around and argue that there's no reason to follow any of that because no one has done a scientific treatise for you to follow...???
OK...how about then you provide a scientific treatise to support your position that distance & angles make NO difference...oh wait, you just said you would rather have 'em closer and with tighter angles.
But...but why...???...if it makes NO difference.
Glen...you're chasing your own tail.![]()
I'd ask you the same thing, miro, what is the science or math behind the equilateral triangle being needed? Stereophonic playback requires the following and the following only: That a listener with two ears have those ears basically in a line parallel to the line between the two playback speakers and that those speakers be of equal distance from the listener. Period. Its that equal distance that ensures that the stereo inage is not shifted right or left because of a bias created by a difference in distance.Maybe we can now put this thread topic to rest....![]()
There is. And what kills me, is how few bother to even look up the science (beyond looking in Wikipedia, which is about as scientificly robust as USA Today.) And as far as testable goes, the definitive tests are to do the math and to measure it with impartial instrumentation. I've explained the math. I don't have the lab instruments to definitively test it, but I trust bot the the math and the results of my own two home studio setups, where these supposed "holes" do not appear. I described in the previous post what I think is what many people think they hear as "holes", when there are no actual holes there.I think this is more than just opinion, it is something that can be tested which means there must be some science behind it.
There's a number of things worth pointing out there. First is the stands themselves; which can noticeably change the sound from your previous setup. Second is you can't put the word "notwithstanding" after the phrase "room reflections"I just bought some stands that close up the angle of the speakers to about 80 degrees from their previous wider angle and SOMETHING sounds better. But if I maintained that angle and pushed the speakers further away, how would that change anything if the SPL measured at my ears remained the same, room reflections notwithstanding?
. Change the positions of the speakers within the room, and those reflections do change, and will affect, what you're hearing.That's the same thing geometry-wise, but not the same thing room acoustics-wise. Which begs a point:I can change the 80 degree angle to 60 degrees by sliding my chair back 2' - but I guess that's not the same thing
Actually there's a couple of points there. The first is you say that things sound "better". I'm truly glad to hear that, but I don't know what that means. How do they sound "better"? Is that "betterness" attributable to an actually more accurate creation of the stereo image itself, or due to something else like a shift in frequency resoinse or something like that?All I can say is that I got a better sound when I pointed the speakers in towards me. And I got an even better sound when I brought one of the speakers in closer so the speakers were equidistant.
When I changed the angle, that is, pointed the speakers inward, I heard one level of improvement. When I brought the farther speaker closer in I heard another level of improvement. Once again, the word "improvement" is qualitative but I hope you get my meaning without me having to use words I don't have to describe something I experience with my sense of sound. I dont think there is an onomatopoetic word to describe the improved "quality" of the sound - but it sounded ... better.. to me after both of these changes. I did say that a hole that I was previously unaware of had become conspicuous by its absence when I closed up the speaker separation. I don't know how to describe it any better than that.
