SouthSIDE Glen
independentrecording.net
Diggy, Id've thought you'd have figured out by now that absolutely nothing Greg_L says on this BBS can be taken seriously.
G.
G.
G.
G.
I'll PM you when I get to work. But if you posted it here, everyone would know what you're talking about.
I failed at my communication apparently. I love compression. Compression is awesome. And I would never suggest that a "nothing but faders" mix is anywhere near a finished mix. And when it is time to mix by all means use every compressor, eq, automated fader, delay, etc that you need.There's nothing wrong with compression or compressors. To borrow an oft overused recording cliche: compression is just another tool in the box. Sure, it can be abused, and it often is, but that doesn't make compression bad. This whole notion of everything having to be perfect as you track is awesome in theory, and it should be a goal, but it's very unrealistic. If you come up a little short, that's okay. ... It's foolishly idealistic and naive to suggest that a mix should just mix itself with all faders at zero. If a compressor makes a track or a whole mix sound better, then use it. Don't be dumb and refuse it based off some stupid principle.
Why does everyone seem to think compression is only about making something loud? It can be useful in so many other ways, too. Smash some peaks on a single track without turning up the whole thing afterward. Use a slow attack and release to leave the peaks alone and fatten up a drum kit. Keep that chickin' pickin' consistent. Get more apparent headroom out of your clean instrument amplifier. Make an instrument pump and breathe on purpose. Double you tee eff.
This goes a long way for saying keep things simple and to plan ahead but if you think about it that doesn't really address the OP's problem.The idea of recording "the whole sound" and just concentrating on capturing the notes when recording and then cutting away frequencies that you don't need in mixing... That's the very essence of "fix it in the mix".
Carving notches with EQ might fit everything into place just fine, but it won't sound as good as much less EQ on a part played with a tone and touch that just inherently fits.
But mixing is not taking something that doesn't work together and hammering until it does work together. If your vocals are buried out of the gate and a simple slide of the fader won't dig 'em out, something is wrong.
It all fits. It sounds like a professional mix. There are a million things that could be improved if a multi-track existed and mixing could be attempted. But nothing is broken. Leads come forward because the band plays them forward. Bass and drums don't step on each other because they are aware of each other. This is what I'm talking about.
), but it sounds better. IME, 20 tracks with a busload of post-processing almost always sounds worse than 20 tracks with less post processing on them. The processed stuff tends to just sound more "muddy", whereas the cleaner tracks sound, well, cleaner.Compression only sucks if you overuse it. Subtlety is the key.....
