T
T.Perpendicular
Is there one type of head cleaner better than others. What do you use? Does anyone just use alcohol?
How is chemtronics head cleaner II?
What if you're bald ?I find that any shampoo will work if you use a good conditioner afterwards.
And of course, brushing or combing in between helps.
I still prefer the 100% cotton makeup remover pads....
Its a whole lot easier than a cotton swab I'll tell you that much, because you can bunch the pad up and shape it to the cranny...just try it. The larger surface area is nice too because you can wetten the pad with the cleaner without having it saturated and there is more area to capture soilage. They are cheaper than the good-quality wood-stick swabs too. Just try it and see what you think...after all, we're all friends here...right??
