PDP
There once was a note
How common is stem-mastering now, in regards to present day DAW mixes. If I want to send out a mix to be mastered is it the more accepted practice ?
This is exactly what I don't get about stem mastering *if one has a choice*. If there's some logistical reason to send off stems that can't now be avoided, that's one thing. Things like like running out of mixing time/budget, or the stems are coming from separate studios, are some examplesso much more often than not, it seems that the engineers are looking to "pass the buck" on mixes that they/their clients don't want to commit.
But if there's no logistical reason to forward the stems, if it's just a personal preference, then that pretty much labels the mixing engineer as unqualified to mix, and the mix itself as unfinished. The answer to that it seems to me is to get someone else to finish the job before sending it off to mastering instead of sending an unfinished mix to mastering.
IMHO and all that jazz.
G.
G.
The best solution in such cases are to fix them in mixing before they even get to be stems. Of course, if the mixing engineer is not up to the task, then that's a different story. But then the question is, if the mixing engineer cannot do his job, then why is he even doing it to begin with?if you have a high quality mix, then there is no reason to master stems, but if there are smaller (or bigger) problems, its better fix them without compromise on the stem tracks than on the masterbus. typical things were i request stems:
- some levels (mostly bassdrum+bass do not match or vox) levels are not correct
- vox or some instruments have too much dynamics or are not well equalized
If they're going to spend money on someone to get the job done, then they shouldn't spend it on someone who can't do the job. If the mix engineer can't hand a finished mix to the mastering engineer, then the mix is not ready to be mastered.e.g. because the budget is tight
Of course it's impossible to say for sure without knowing which specific recordings (and which specific re-mastered releases of those recordings) you're talking about, but there's no good reason why one should be able to hear whether a song was mastered from stems or not. Chances are what you're hearing is just an engineering and producing style result (tracking, mixing and mastering) that has a particular character of sound you like.However, there is a mix on some records where the vocals sit so nicely, like their separate, yet not standing out at all. I cant help wonder if thats a result of the instruments and vocals being mastered with separate stems, or just a great mix. Its a distinct sound, I've only heard on a few recordings.
See, this is where the question gets muddied up. Which Quadrophenia mastering job are you referring to, the British LP of 1973 or the American one? Or maybe you're referring to the MCA CD set remastered in 1985, or maybe the Polydor re-release remastered again in 1996? Or possibly one of the many vinyl singles separately mastered in '73 and '74?Like the Who Quadraphenia, generally mixes that have loud power guitar sounds.
stem-mastering isn't intended to finish a whole mix during the mastering-session. the mix itself should be finished. but if you just would like to pull down the bass for e.g. 2dB, you do that better on stems, because its more difficult (or even impossible) to do it on the masterbus. you could now argue, that a mix is not finished if the bass is too loud, but hey...mastering also includes sometimes fixing. if you pay 1 or 2k$ for mixing, that *shouldn't* be needed (or you got ripped of ;-)), but current budgets are tight & people are mixing by themself or can't pay much für mixing, but want to have the best possible result - and this *could* be achieved if you have control on each individual stem.If they're going to spend money on someone to get the job done, then they shouldn't spend it on someone who can't do the job. If the mix engineer can't hand a finished mix to the mastering engineer, then the mix is not ready to be mastered.
Like I said earlier, if logistics dictate that the ME be handed an unfinished mix, that's a different story. But the whole idea of *purposely* waiting until the final stage before getting things right is just ludicrous. Its like waiting until the painters come in to make sure the walls are built to spec.
I don't want to give the impression that I already knew all those details in my head. I looked them upHahaha,
I kinda figured you'd know all that, and it pretty much answers my question.Have a good Holiday !
