T
The Ghost of FM
Banned
Good stuff and best of luck with your future projects!
Cheers!
Cheers!
Awesome! Will give it a try. Gonna get the tach roller fixed then shes good to go! Pretty excited about this machine.
Oh yeah, note that in my diagram, the bottom of the picture is the tape-facing part... the top, with the q-tip shaft is the back side, facing away from the tape.
Do you guys know if the MSR16 and TSR8 have interchangeable MRL calibration tape?![]()
I cut about an inch of straw for each lifter, basically enough to cover the exposed metal.
The first thing I did was just leave them loose, the idea being that they'd work as cheap rotary guides and reduce wear during winding. However it made this horrible violining sound during fast wind, so I stopped that experiment fairly quickly.
What I did instead was find something to stick into the loose part of the straw to bring it tight against the tape lifter, like this:
...I ended up using q-tip shafts since they happened to be the right size and were plentiful.
The straw would be thicker and last longer. It would also have the advantage of being seamless. Splicing tape is gonna have an edge somewhere plus whatever goo from getting it to stick together on the post.
Cheers!![]()
Yeah, I've only done this on the lifters myself. The other guides can be rotated.Ok I'll give the straw thing a try, but other than the tape lifters...I doubt a straw would fit on the 2 other guides, and definitely not on the 3rd large guide on the MSR16.
Thanks for all your help!!
Kind of off topic but can I do something similar to the lifters on my Tascam 22-2?
Different lifters on that one, like needles, so I doubt straw would work.![]()
You might need to visit a local bar which has those skinny straws for their girly drinks!
Cheers!![]()
