T
tbrowne
Hello here are two questions rolled into one
First of all I have a set of KRK Rokit 5s which I love, but I also have a pair of Eclipse speakers which I would like to run at the same time, on my MacBook Pro. Can I simply use a headphone splitter? Won't this "damage" or somehow reduce the output to each speaker set? Is there a better way of doing this?
Second, when the Mac is charging there is actually quite a lot of noise coming out of the headphone jack for some reason. I have thought of using the optical output as an alternative to drive my KRKs but that would need a pre-amp or DAC of some kind no? What should I do? Perhaps I can combine the two problems into one ie buy a piece of gear that will take the digital optical out from my Macbook, and have more than one set of monitor outputs?
Thanks for the help.
Sorry I should add that the Eclipses, like the Rokit 5s, are self-amplified.
