SteveM
I've got a soundcraft 200 series, it's not the 200b or the 200sr or the delta and there is virtually no info on this exact model though it is very similar to the others.  The 200b is pin 3 hot and the 200sr is supposedly pin 2 hot (or maybe the other way around).  The other decks are supposed to run at +4 but I've discovered that my Tascam has a louder output than this does.
 Also the meters on this are getting pegged while the Ampex is getting a very low meter reading. The Ampex is right, because I've been using it with other gear.   I know that some of these are supposed to have switches where you can switch between -10 and +4, I looked inside to see if it had been changed and I found no such switch inside. Also I can't tell which pin is wired to which because the jacks are enclosed in a box.
Does anyone know anything about these boards? Would having the pins swapped actually make the output lower even though it seems to sound fine?
 Also the meters on this are getting pegged while the Ampex is getting a very low meter reading. The Ampex is right, because I've been using it with other gear.   I know that some of these are supposed to have switches where you can switch between -10 and +4, I looked inside to see if it had been changed and I found no such switch inside. Also I can't tell which pin is wired to which because the jacks are enclosed in a box. Does anyone know anything about these boards? Would having the pins swapped actually make the output lower even though it seems to sound fine?
 I'm basically just using it to sum drum mics.
