Fret Buzz Diagnosis
  • Thread starter Thread starter nate_dennis
nate_dennis
nate_dennis
I know it's tough to diagnose fret buzz over the web, but I'm hoping this is specific enough of a situation that you can help.
My acoustic only buzzes on one fret on one string. The third fret of the high E string is the culprit. Does this bring any issues to mind or is it still way to broad? Thanks so much.
The third fret is either too low (unlikely) or you have a high spot on either the fourth or fifth fret. If you aren't familiar with fret dressing, take it in to tech and have him do it. It's not a big job.
You can test for the high spot using a small straight edge. It will rock on the high fret.
Look at that fret; it's probably cupped. Playing lots of G chords will take a divot out of the third fret where the E string hits it.
Acoustic or electric?
If you have a buzz, always suspect the next fret up from where the buzzing stops. See if that fret is loose (popped up).
Could be the divot that Ggunn talked about. I which case you need a frett leveling.
OR- you could just try raising the action just a smidge (that's a technical term)
Actually, it's more typically the next but one fret but your advice is sound..
