T
Terra
Scholarly Gentleman
Just wondering if i should invest in one or not, seeing if it was worthwhile.
Before you invest in a sub check out bi-amping here:
http://sound.westhost.com/bi-amp.htm#common-question
Why would I be considering this a newbie question? I don't mean to say it eliminates the value of a sub and not everyone use active monitors. I'm just thinking it's a step to take to clean up your sound(mud) before investing in a sub.It is my understanding that most active monitors are bi amped today? (I know the JBL's are)
Perhaps you consider this a newbie question, but what does Bi Amp do to eliminate the value of a sub?
I treat the Sub just like I do Headphones. I do not mix with them, but I do check my mixes on them.
Cj
Understand now and agree with you.
1) get the room treated as best you can
2) get as "good" Bi Amped monitors as you can afford
3) a sub helps you check your mixes for low end crap
Or low end rumble.Whoa.... Deja vu
first of all, thanks y'all for all the replies. I use Alesis m1 active 520's...just a $200 pair of monitors...I think instead of investing in a sub, I'm going to invest in some better monitors, probably with larger speakers in them, mine have a 6" driver, puts out some bass but 0 sub frequencies (~20-70hz). I was looking at the Yamaha HS80M's. (what do y'all think of those?)What speakers do you have now? I much prefer a single pair of full-range speakers that can get down to 50 Hz or lower, rather than lesser speakers with a sub. But regardless of which speakers you have, unless you have bass traps you're not getting their full potential anyway.
--Ethan
Cj
I mix with a sub, but whether you need to or not has a lot to do with the satellites. My mains are M-Audio SP5B's, which are notoriously bass-deficient. When I spoke with the M-Audio regional rep (a lucky chance meeting), he told me that the bass ports were placed in the back of the SP5B's on purpose, as they were always intended to work with a matching sub. If I had some nice Genelecs or whatever with 8" or 10" drivers, I'm pretty sure I wouldn't need the sub. As it is, the SP5B's and the SBX work together very well, and I've learned to mix with them. What the hell?-Richie
