acidrock
GO PACKERS!
That depends on the characteristic impedance of the cable, you just have to check if it's 75 ohm . . . and also its length. The rule of thumb for a cable to act as a transmission line is 1/10 wavelength, which for S/PDIF (running about 3mHz) is 10m. Really, S/PDIF is rather tolerant of peccadillos . . .
AES, on the other hand is designed for longer cable runs, if so you should seek out 110 ohm cable.
Well I've tried it with short RCA cables and it didn't work for me,plus everything I read has said to get the proper cable.A SPDIF cable isn't very costly,why would anyone recommend using an RCA cable if there could be potential problems?
Which cable would you recommend?
