S
sotorious
When to use them and when not to use them?
That's like asking when your body uses temperature, blood pressure and blood type and when it doesn'tWhen to use them and when not to use them?
. It's not a question of using them, they are always there and are always "used".Any amount of compression is almost universally going to make bad rooms sound worse.All this stuff makes me want to rip my hair out. It just seems that i have a hard time making the vocals sit right with in the beat. It may have a lot to do with my room as i am recording in a wide open room. I also get this hollow sound.
Just to expand on this. The reason this is true is because compression will make any ambience that has been recorded along with the sound more apparent, especially at fast attack settings.Any amount of compression is almost universally going to make bad rooms sound worse.
Also does anyone have any instant messaging programs, so i can get someone one on one. and wont flood the forum with dumb questions.
Believe me - They all have hard (usually a.k.a. "brick-wall") limiting (God help us all, they all have hard limiting).I have a tool i use called "hard limiting" i dont know if its in any of the other DAWs im sure it is, just incase its not its a form of compression that brings the lows to a good section and the highs lower if they are to high. If i also just add another compressor ontop of that will that be to much?
Not something you'd really ever use on a vocal track though...
Hi
It sounds like you're just using a compressor because you have one, not because you understand why you need to.
I'd go back to your vocal and try to re-take it minus some of the issues you have.
Its mainly for the different levels isnt it as if i start yelling in the mic it would bring it down a notch or so.
Or break them down and each would make a title for a KMFDM song. Hell, they already have songs called "Release" and "Attack". Not sure about "Threshold" thoughThe title of this thread would make a good album title. Or a 17 minute progressive rock epic title.
