6
6 String Dream
Why do people set up microphones and recording desk in seperate rooms? Wouldnt it just be easier to have in the same room within a smaller space?
I don't.Why do people set up microphones and recording desk in seperate rooms?
Need to emphasise a big one that has only just been touched upon...
Getting the correct sound coming through the monitors (by adjusting instruments, mic choice, placement, etc) before you hit play is virtually impossible without good isolation between the control room and live room. If you're all in the same room you have to go through the endless cycle of recording a bit, listening back to it, tweaking the setup and repeating until you're happy.
Let me pile on to this one. Yes, this is why you would do that.Need to emphasise a big one that has only just been touched upon...
I am contemplating using a pair of webcams over my network to get around the fact that I can't see the musicians.OK, you have two different issues with the room mic.Everything is fine when just using two mics going into the soundcard. As soon as i add a third (room) mic using a mixer as a preamp, i start getting funny squeaky noises and the volume also cuts out in my recorded take.
Then having a separate control room isn't going to help you much. Probably the only benefit would be if you had a room in the house with good acoustics for recording but couldn't set up all your monitoring gear there permanently, so had a separate room for that. That's what I do. My living/dining/entry is pretty big, with high ceilings. It's also decorated by my wife, heh. My control room is a bedroom a hundred feet away, acoustically treated with 703 panels. I have mic cables running through the wall and hanging coiled in a closet in the tracking room when not in use.Im just recording myself which is vocals and acoustic guitar.
