S
soullavee
Hi All,
Does anyone here know the best way to convert a cubase audio mix-down[wav]to MP3 without volume fluctuations? for some reason after exporting the audio mix-down from Cubase and converting to MP3 the mp3 file plays with volume fluctuations ie plays loud than drops than up again in some sections and so forth, it sounds like compression kicking in and out, so i tried exporting the file from cubase without compression[i switched the compression off on all the tracks] and it's not doing it. however, i can't not use compression on the tracks as some need it, so does this mean i can't convert wav to MP3 while compression is used in cubase? is there a way around it? what's the best way to convert a Cubase wav mixdown to mp3?? please help , this is very urgent!!
Thanks in advance,
Thanks in advance,
