Using Studer A827 without console ?
  • Thread starter Thread starter Baster
B
Baster
Hi all
is there any way to record, monitor (without latency) and mix without console to studer ?
I'm not sure I understand. By 'console', are you referring to the machine's control panel, the remote unit, or a mixing desk?
If your question is "Can I mix something without a mixing desk", the answer is basically "no"...
Yes i was referring to mixing desk
well forget mixing part then, can i at last lay down song to those 24 tracks and then do mixing part digitally in pro tools? digital link between Studer and pro tools would be apogee 800 which is 8 channel high-end ad/da convertor.
How do you plan to mix those 24 tracks to 8, or are you only using 8 tracks of the Studer, or are you only planning on monitoring playback of 8 tracks at a time?
If it's the latter, and the plan is to import them in three groups of 8, you might have a few problems lining them up afterwards, since the machine will not run at exactly the same speed each pass.
Wouldn't it be cheaper and easier to just get a Tascam 38 or something, if you're basically using it as an 8-channel effects box, rather than what it was designed to do? Or mixing digitally and bouncing the stereo mix to 2-track tape?
If you want to bounce a 24-track digital project to tape and back again, you'll need 24 digital channels to do it properly.
Have you considered the running costs and maintenance? A 24-track machine is likely to be a pig to align :-S
I need all 24 channels
and this seems to be one big mess, adding more ad/da convetors will cost more then i can afford, i think it would be better to get some good cheap mixer, right ?
but what im afraid is if i run signal thru some cheap mixer that source will be degraded, and i dont have money for SSL console or neve.
my gearlist:
daw:
pro tools le 8 - digi 003r
mac quad core pro
UAD 2
mics:
neumann u87 vintage
neumann u47 fet
rode k2
sure sm7
preamps:
neve 1073 dpa
focusrite isa 110
avalon 737 sp
compressors:
urei 1176 silverface
universal audio la-2a
dbx 160x - x2
effect processors:
lexicon pcm 70 ver 2
eventide h3000 SE
my gearlist:
daw:
mac quad core pro
UAD 2
mics:
neumann u87 vintage
neumann u47 fet
rode k2
sure sm7
preamps:
neve 1073 dpa
focusrite isa 110
avalon 737 sp
compressors:
dbx 160x - x2
effect processors:
eventide h3000 SE
Ok I'll bite. But say it isn't so.
I saw this yesterday and the 827 was a dead giveaway. The world can't be to the point yet where people are now buying 60K ($20K closeout price) recorders and don't know what to do with it. http://cc.bingj.com/cache.aspx?q=ne...32&mkt=en-US&setlang=en-US&w=f8ced85,a14b1a4e
With the list of gear you already have, if I were you, I would look around and try to find either a API or maybe a Quad 8 console. :D Or if that won't work maybe a Neve V.
Suggestions for 24 channel mixers are accepted
budget is limited: 2,500 $usd
I'm not quite sure what to make of this thread. It wasn't started on April 1st so I'm out of ideas. ;) Are you serious Baster or just goofing around?
Maybe with the differences in timezones it was April 1st in the Country of Dreams with the thread was started.
Frankly, I'd say that if you can't afford more AD/DA channels, you're not going to be able to keep the machine running :-S
You may be getting it for less, but at the end of the day it's a £30'000 tape machine, and it's going to cost a shedload of money to run. There's a reason I haven't upgraded to a wide-track tape format...
http://www.gearslutz.com/board/rap-...duction/457856-going-digital-studer-a827.html
