D
dontouch
In a scenario when combining vocal tracks, is there a sonic difference to add reverb to the group track vs. to add the same amount to the individual each vocal track?
Thanks!
Thanks!
Thanks!
Why wouldn't you just use 1 verb on 1 aux and another for the group aux...?
(EDIT) Or are you actually using reverb as in insert??? On individual tracks...?
Well, if you like it...
No I don't do silly things like using reverb as insert.
I'd imagine any audible difference would be negligible and it wouldn't surprise me if the send from the group sounded more 'unified' than sends from individual tracks. If you definitely want to apply the verb to the signal as a whole, there's nothing illegal going on.No I don't do silly things like using reverb as insert. I just want to know if adding to the group makes a difference in sound. I listened back and forth and honestly I can't tell. I did feel like there's slight more unity but I can't say for sure. 3 vocals, one in center and 2 panned L8 and R8...They were from different takes(not duplicate).
Because it's generally just not done that way...?why is that (reverb as an *insert*) silly?
I do. In fact, I do all kinds of "silly" things the merit of which I judge with my ears.
In general I agree with everything you say, and I'm not advocating inserted reverb as sonically superior. But there are times when I need none of the advantages you list and I don't want another aux loop for a reverb applied to just one instrument. When an effect is good enough to sound exactly right there's no advantage to being more than good enough. When it isn't good enough to sound exactly right I make a new aux, simple as that.It has nothing to do with ears. It's just a really odd and very inefficient way to add reverb...
Even with *one* send -- The amount of control over the signal is either (x NONE) as an insert or (x EVERYTHING) as an aux.
It's a rather rare occasion that I'm not compressing or EQ'ing (or both) or pre-delaying or modulating (or any of a host of other things) to a reverb send... Can't do *any* of that as an insert. Can't send anything else to it as an insert. Can't solo it as an insert. Can't mute it as an insert. Can't buss it somewhere else as an insert.
RULE OF THUMB: You want to *affect* a signal? Insert. Typically EQ or dynamics.
You want to *add to* a signal? Auxiliary. Typically, everything else. Delay, spatial (reverb, reflections, echo), modulation (flange, chorus, phaser), etc., etc., etc.
...not only that, but when you insert a reverb, you end up with mono reverb on that track. If that's what you want, cool.
Not in the DAW I use.
Not in the DAW I use. [Edit] But it does pan with the track, which is sometimes what I want and sometimes not.
For conventional stuff, such as placing things in an acoustic space, yes, I agree with you.It has nothing to do with ears. It's just a really odd and very inefficient way to add reverb...
3. This is going further into electronic esoterica, it's sometimes desirable to have a filter (HP, BP, LP or whatever) to act on the overall source+reverb sound.
4. There are times when I want the reverb and the source sound to be distorted together, so, I will put the reverb as an insert followed by some distortion as an insert. Granted, this is an extreme case, but nevertheless, is the only way to get the desired effect.
Actually, out of curiosity, if you insert a reverb into a mono track, and it pans with the track, how does it manage to be stereo? I'm probably still thinking too much in hardware terms, but it seems to me that if the reverb is being inserted into a mono track, it would be summed to mono, no? I'm just asking because I'm not sure if I understand it.
You're right. It will be summed to mono. It might or might not be desirable. If you want to keep the reverb itself in stereo, you have two options. You can either send your mono track to an aux send or route your mono track to a stereo group/bus and then insert the reverb on the group/bus channel.
It may be the case for whatever DAW you're using, but it's absolutely not true for the one I use.
