D
dum6sh1t
Hi ya'll, Newb to the forum here. Great place! I've been lurking for awhile and it has helped tremendously with most of my questions using the search function. However (here comes the newb question), I am failing to understand mics being out of phase on a drum.
Let's use a snare drum for example with 2, sm57s top and bottom for sake of discussion. Now is the "out of phase" referring to the gap in time from the initial attack of the top head to the register of the bottom head? I am assuming one would want both diaphragms of both mics to oscillate congruently. Meaning if mic A (top) picks up top head going down, you would want mic B (bottom) to pick up bottom head going down simultaneously. This is where I get confused. Does it even matter if each mic is running through a separate track on the mixer? Is it a simple matter of switching polarity on the mics(re solder an XLR), or is there a third party piece of equipment necessary to eliminate this?
Also, if the case may be that it is just a matter of switching polarity and I choose to use other condenser mics, will phantom power be an issue?
