Bouncing Down at Highest Quality Possible?
  • Thread starter Thread starter Steve Henningsgard
A HA! It's all coming together now. I really gotta get my head around more of these concepts. The fun thing for me is that, the technical mumbo jumbo gets more interesting to me each day. If only I had the ears! :confused::eek:
Generally technically speaking (just for a second, bear with me here, it'll come together, hopefully...) a linear process is one where the initial value pumped through the equation/algorithm is an original or independent value each time. One example might be if you took a sample value and then plugged it into the the math to get a result. Then you take the next sample, pump it through the math, and get a second result. Peak normalization would be a good example of this, where you take each sample and add the same amount of gain to each value. Each iteration of the algorithm that the plug runs is independent of the others. That is, the resulting change to sample 5 has no bearing on what happens to sample 6.
A non-linear process is one where when you iterate through the equation/algorithm, the results of the first iteration become the input values of the second iteration. That is, you grab sample 5, run it through the math, and then the next iteration of the math ain't taking the value of sample 6, but rather the value that was the result of the first time you ran the equation. Then you take that result, and churn it through the math again. And so forth for as long as the plug's algorithm is programmed to do it. Then it may or may not move on to the next sample and start all over again, depending upon the program. With reverb, this is kind of obvious, because it has to calculate the bouncing and decay and so forth of more than just the first reflections of the sound. It has to also calculate the way the first reflection bounces a second time off the opposite wall, the way that then bounces a third time off the ceiling, and so forth. This is why really good reverbs are such CPU hogs, there's a whole lot of re-calculating going on.
Because of self-referencing of non-linear math - the using the output of one iteration as the input of another iteration - a lot depends upon the accuracy of the equation's output. The more iterations, or cycles, that the value gets churned through, the more the amount of error will build up. Now it's pretty obvious that a nice floating point plug will allow more digits of accuracy than a standard fixed-bit plug.
I admit that I don't quite know off the top of my head why an increased number of samples should matter. But this post was not meant to answer that, just to define the difference between linear and non-linear processes.
G.
What exactly is meant when you guys say "non linear processing"? Can you give an example where you can confidently conclude (even w/ aggressive processing) that upsampling has a positive effect.
Hi Erock. In the case of Rverb, non-linear is a bit of a misnomer, as it really refers to the reverb's decay envelope. It allows you to create gated reverb effects for example.
In general when we talk about non-linear processessors we mean things that normally cause some sort of distortion, this can be saturators, distortion plugins, compressors, etc.
If you have a compressor that can distort for (the UAD 1176LN is really good for this for example), then give that a try. Another one that comes to mind is PSP Vintage Warmer. Or try some kind of distortion/saturation plugin.
Reverb by its nature is not going to generate higher frequencies on its own.
Did you make up that phrase?:D
Yeah, probably...but not on purpose; I meant to delete "technically". :o
Come on, star, you should know by now that late night posts on my part are usually riddled with those kind of mistakes.*
*So are my morning, mid-day, afternoon and evening posts. Otherwise, I'm fine.
G.
