Mick Doobie
Maderator
If anyone would be so kind...
I'm new to recording...a newbie...and just got a Tascam 2488 neo for Christmas. Anyway...
Edit: I'll place this edit up front to jump to the chase instead of possibly confusing the issue with ramblings. Short and sweet: When using a pre-programmed drum machine, and then laying down the track, if I am later after recording guitars unhappy with the drum track, how can I avoid re-recording all the guitars if I later decide to replace the drum track?...how do I synch a new drum track with previously recorded guitar tracks?
...end of edit. More explanation below if needed.
I have a question about synching the drum machine with previously recorded guitar/bass tracks. For instance: I've programmed the entire song from the get-go on the drum machine(Boss DR670..kinda sucky), and then lay down the drums on stereo tracks 23/24. Then, I lay down a bass track(track 1), and also a guitar track(track 2). However, at this point I hear flaws in the drum track. I go back and pan the tom(s) and hi-hat, or cut back the level and fatten-up the snare. Say I like the bass and guitar track(s) and feel they are keepers. But if I want to replace the drum track, how do I synch the drum track with the previously recorded guitar and bass tracks? The best I can come up with thus far is to click the start button on the drum machine in relation to the other tracks...which is iffy, and depends on me hitting the start button on the drum machine at precisely the right millisecond. This method isn't cutting it. I'm sure there is a proper and much better method that involves click, and is probably spelled out in my manual. But hell, I'm trying to get some recording done, not become a technician, although I realize that recording and knowing how your gear operates are both necessary elements of successfully fullfilling future goals. Maybe a bit of advice combined with reviewing my manual with the advice in mind would be more helpful than simply reading the manual and groping around to solve the problem
I'm just looking for maybe a slight headstart in the right direction. If anyone can give me a nudge, i'd appreciate it.
Thanks.
Thanks.
