G
gibsonsgharp
As I am new to this site, I posted this question on the "Techniques" forum but realized that it might be a more appropriate question for the "Mixing Mastering" forum.
My overall approach has been to record each instrument/voice on one track, recording it with desired EQ/FX/Reverb using external mixer getting each track to sound as desired. Then mixing each track using fader,pan, etc. into the "final" mix. Then, if necessary, adding something via the software, usually reverb or some final EQ, to each track or the mix overall if needed to the "final" mix. Results have been "amateurish". The subtleties of each track get lost in the mix. (i.e. that reverb/echo on the vocal is washed out by the rythmn guitar)
From the response on the other forum, I am thinking a better approach would be
1. Get a better computer so I dont have to worry about software EQ/FX/Reverb eating up processing resources and only use external devices if desired sound cant be achieved by software modules
2. Record Dry
3. "Inital" Mix Dry - using faders and pan
3. Add FX and EQ where desired
4. Add reverb to individual tracks as desired in the mix
5. Add reverb to the overall "final" mix if desired
6. Normalize?
I am new to this , (my previous recording experience was on a Tascam 4 track with cassettes) so I have a vague understanding of what "Normalize" is and when to do it. Does most software do this for you?
Thanks for listening and any advice.
2. Record Dry
6. Normalize?
