M
mystonicrecords
Normalizing is no worse than raising the gain at any point in the process.
The problem I have is anyone using software in any way to raise the level of something initially recorded. Period. Ideally it should not be done. Reduction, yes. Raised no. What am i missing?
If I have a recording booth with an actual noise floor of -70 db, that means from my understanding that from 0 level I have 70 db of room for my signal. (for instance i should be able to see my volume meter before I start singing or playing, and it will be hovering at -70 db) So if you are recording your track into the computer and the peaks of that signal are coming in around -20 you are only getting 50 db of room for your signal, as the noise is still waiting there at -70. So to increase volume, post recording in any fashion, you are increasing your noise level. 10 db increase post recording and you are now having a -60 db of room before noise.
If that's true then why are you not always going to bring in all material at just below 0 level during recording.
I thought this was a basic, recording 101 point, but I have no high degree on the subject. Please straighten me out as needed, you masters of mastering. And i know this is not necessarily a mastering issue, but rather a whole process issue. IMO mastering is a whole process issue.
. You can decide for yourself which way of looking at the whole process works best for your own personal sensibilities; whether you're more of a tactical guy or strategic guy. Whatever one works for you.
