Farview
If the sound coming out of the amp in the room sounds like the EQ'd mix sound (CD sound), that's bad. if it sounds more like the naked amp sound (raw), that's good.i listened to your lacuna guitars. one is just naked amp sound, another is just eq'ed mix.
Yes, that is all you can do. There is no magic trick. You just have to adjust the things you can to get the sound you want.and if im not satisfied with the sound after the mic, i adjust distortion amount, frequencies, mic position or the way of playing.
is this all i can do?
The big problem people run into is wanting to get a sound that they can't get from their equipment. If you want the sound of a les paul through a Marshall and you are playing a strat through a Crate, it's not going to sound right to you no matter what you do.
