Need help configuring Audiophile 2496
  • Thread starter Thread starter Laynestaley
L
Laynestaley
Newbie Shmewbie
I've recently bought myself a new desktop with Windows 7 64bit. I installed my Audiophile 2496 and the latest driver (5.10.0.5074). Windows recognizes the card and there is sound.
As a playing device I can only choose between S/PDIF and Line 1/2 so I selected Line 1/2. As a recording device I can pick either Line 1/2, Monitor and S/PDIF. When I select Line 1/2 I can record but there is a terrible latency. When I select Monitor there is no latency but the sound hangs (keeps repeating very fast).
I should also say that it worked ok yesterday (I had selected monitor as recording device), but because there was some minor stuttering on playback I decided to experiment with the settings (de-installed the soundcard and installed it again) and now I can't get it to work properly.
I've included a few screenshots that might shed some more light on things. Any help is much appreciated.
Hi Laynestayley,
I had the same problem with the M-Audio card when the drivers first got released for it. The reason why you're getting the non-stop sound when you click the monitor is because the audio is in an endless feedback loop.
Both playback & recording defaults should set to Line 1/2.
Which application are you using to record? Make sure that it is set to the M-Audio ASIO Driver (if your application uses ASIO) otherwise the application will default to using the on-board sound ASIO which usually has large latency issues.
Actually.. I think I may remember why this happens.. Totally forgot about it..
I did/do have the latency issue also. The only real way to get around it is to:
1. uncheck "Listen to this device" in: Control Panel-> Sound-> Recording-> Right-Click on Line 1/2 on M-Audio Delta Audiophile-> Properties -> Listen-> Listen To This Device
2. Go to your DAW recording program and enable monitoring on one of the recording channels.
Unfortunately it seems that it's a driver issue as I've never had this kind of thing happen in XP. Thankfully I have a dual partition with XP and 7 so I don't really notice it.
Hope that helps.
Hope that helps.
Unchecking "Listen to this device" did the trick. Latency is gone now. Thank you.
