C
Chrisdb
I only have one on my Mac Mini and if I want to use a firewire external hard drive and 002 Rack, i need two?
Is that possible?
Thanks
Is that possible?
Thanks
I just found this where it looks like the digi 002 should be the last device in the chain....
"Should I hook up my FireWire drives to the second FireWire port on the Digi 002?
No. The second FireWire port on the Digi 002 is NOT intended for external hard drives or other storage devices, as this may result in unexpected behavior. It is recommended that Digi 002 be connected as the last device in the FireWire chain, or be connected to a dedicated FireWire port."
Digi 002 and firewire
So it looks like you would want to hook it up:
Mac <---- Hard Drive <----- Digi 002
Hopefully your hard drive has 2 firewire ports for daisy chaining.
daisy chaining audio interfaces and hard drives is a big no-no
its hard to say exactly. You could try to contact the seller and see if they know. The hard drive you linked us to is capable of daisy-chaining but they really only say to daisy chain to another hard drive. That doesnt mean it wont work.
However, another option is this product witch will give you 2 firewire and a bunch more usb and its made for your mac mini:
http://www.newegg.com/Product/Produ...28&cm_re=firewire_hubs-_-33-314-028-_-Product
There is always a way to do what you want to with computers. Your only problem is your limited sometimes because its a mac and more so cause its a mac mini. PC's have way more options for usually way cheaper prices.
Even so.... that Belkin hub has some good reviews and belkin makes good products. I have a wireless router by them that works better then any other big name routers ive owned. Im 2 floors away from my g-plus mimo and getting 4 bars.
Search for firewire hubs if you dont like the mac mini one but I think thats the way to go.
