muttley600
Banned
Gosh, maybe I should put up a poll.![]()
I can suggest one place you might consider putting that pole.
I can suggest one place you might consider putting that pole.![]()
Let's use a different assertion:The person that asserts something as fact (as you did when you claimed that there is a "theoretical dead spot" next to the saddle contact point) bears the burden of proof.
Stop it Gaylord.![]()
make me.
You need to understand something here.
The person asking you to provide proof is under no burden to disprove the original assertion.
If you cannot back up a statement of "fact" with evidence, then it remains an untested hypothesis and its validity is indeterminate. Story over.
Google a few articles on basic physics and vibration theory.Can you prove me wrong?
VP
When you state a "fact" that you cannot substantiate to any objective degree, then the usage of the word fact is indeed a lie. You would probably call it "theoretically possible" thereby not false. That form of rationalization is a lie and a deceit at the most base level. Figure it out. It aint rocket science.
Didn't say that was the only reason. Go back and reread the post.Something has just occured to me. If saddle offset is exclusively determined by the act of pushing down the string to the fret, then intonation offset would be a function of string height and action. I typicaly have very low action on my guitars, yet the saddle offset seems pretty typical for even a high action guitar with the same size strings. Experiment: I take my 2 LP's and leave one with low action and raise the action on the other. Then I reintonate. If offset is only because of strings being pushed down, then the 2 guitars should have different offset lengths.
VP
Isnt that called faith or maybe an imagination? It is not a lie. Okay so I dont start every sentence with "I believe" or "It seems to me" or "I feel". You are just like the other loyal nitpickers.
VP
The bigger reason is the different diameters of the strings mean that you get different ratios of mass to length when you fret them.
That's why you have to re-intonate when you change string gauges even though you don't change the string height.
So you are saying there is absolutely no such thing as I propose as the point of contact drifting a bit because of the larger and stiffer string? You know all of the physics involved? You are so sure of this? No possability whatsoever?
This is way too easy, so I'll refrain.That is what I like about this whole Forum, It is all art and science.
Btw if you did start off with "It seems to me", or "In my opinion" or "I think"....you'll catch a helluva lot less grief around here. IJS
The majority of the time I do!
VP
Yes I am saying this as a fact. Am I lying?
The sun is made of flaming beagle farts.
Prove me wrong!
