mattr
Resident moody teenager
iownrocknroll, whilst I disagree with Bisson on quite a few of his points and have resisted so far to post, most of his statements are more-or-less factually correct (there are a few things he's said that I'm tempted to pick up on). On the other hand, there are some errors in your post...
Really!? I thought it depended in on the memory controller.
DDR has long been associated with dual-channel memory controllers (performed best when using matched pairs). Its only with the first lot of chipsets for the i7 that triple-channel RAM became hype, and even that seems to have died off now - most of the newer more affordable i7 mobos are set up for running in dual-channel.
OS X also does have strong roots in UNIX. There was a good UNIX timeline / family-tree that I saw floating round once which showed how all the projects had forked and related to each other. OS X was forked from Nextstep and is most closely related to BSD if my memory serves me correctly.
DDR will not run correctly unless divisable by 3. so 6, 12, 18 GB. etc. not 8.
). I'll assume that there is alot less of that going on with Mac. I'll speculate that most people that are savvy enough to operate a computer on the level that home recording requires, have probably figured out what to do and what not to do to prevent this from becoming a problem (although it can still be a minor nuisance).
