R
RAMI
Guest
well iv sized up everythin after doina studio plan
it looks as if jus the materials them selves are gunna cost me $900 which is fine by me
is dat about right for a room 11x 8 ft
basically takin the floor up , putting acoustic foam inbetween the joists, putting it back down then using acoustic underlay and wooden flooring
then building a frame with acoustic foam all around the room and doubling up on acoustic plaster board
once the room is sound proofed i can concerntrate on building my recording booth which is only going to be a small one either 3 x 3 ft or 4 x4 wt ever suits best
does dat sound about right?
Have you read one response in this thread? Or are you just in denial?
What you're describing above isn't going to "sound-proof" anything. You'll probably end up with a better sounding room to record in, but the sound will still escape big time. You're getting sound treatment and sound proofing mixed up.
, but won't do much for isolation. "building a frame with acoustic foam all around the room" - ie acoustic panels hung on your double drywall? That will certainly help a lot with the acoustics, but won't do shit for isolation. So it won't be a a total waste, your room will sound better. But if you're expecting isolation you'll be disappointed.
), and there is alot of excellent advice there. From what i've found on my own researching, and from what people say here, i'm personally going to use fiberglass not foam when possible.
