noisewreck
Couple of thoughts.
If you try to get things really quiet with the Acer case you've got, you're gonna find out that space is cramped.
You'll need to look for smallish power supplies. Which means anything with a 120-140mm fan is out, just because it will not fit in this case. So you're stuck with one that uses an 80mm fan, which will likely be noisy.
Same goes with CPU cooler.
If you can somehow generate enough airflow in this case, you may be able to get away with a fanless PSU, but don't hope to get anything higher than 400W supply. This may become an issue if you find yourself needing to use a powerful video card for video editing.
