miroslav
Cosmic Cowboy
The most annoying problem we encountered was the LDC would always pick up waaaay too much of the cymbals, and it sounded awful. I know our drummer doesn't have the best sounding cymbals on earth, but they don't sound annoying when you listen live.
The only way we could get around that problem was to move the LDC way out into the room, at which point it captured a fairly nice full kit sound without the harsh/annoying sustain on the cymbals.
Where were you placing the LCD when it was giving you problems?
I use an M/S pair of LCDs as overhead mics...but I place them "inside" the kit...about 4' up and roughly over the drummer's between the Kick and Snare.
You can do the same with a single LCD (you just won't have the stereo spread).
I found that placing the OH mic(s) inside the kit instead of out in front, made a BIG difference in the level of the cymbals, and overall balance with the rest of the kit. Out front, and they are getting hit by the full force of cymbal sound coming off the cymbal edges.
When placed "inside" the kit...they pick up the cymbals off their tops, and there is much less level/energy coming off the tops of the cymbals…plus as an additional bonus, you DO get the sound coming off the tops of the toms and snare. Even the hat will sound good, so you don’t need to mic it individually.
Anyway...with your mismatched mics... I would to a close mic on snare and kick (inside). Put the LCD about 4’ overhead "inside" the kit. And stick the last one outside and further back for some room sound that you can blend in to-taste during the mixdown.
Also, unless the ceiling is real high, you want to deaden a bit too, otherwise you get a lot of early reflections into the OH mic(s).
Of course...this is all "on paper"...so you really have to see what you get in your particular room.
