			famous beagle
Ok, I've owned one of these for several years now, and it's worked fine as a good, transparent, clean pre, which is what everyone says it will do. My complaints aren't about the sound; they're about the design. I'm wondering if others have had these same complaints.
1) The VU meters are set too far back! You have to have the unit near head level in order to see the numbers. I don't see why they did this. Who normally has their equipment that high? I suppose you could put it in a table-top rack, but ... see #2.
2) All inputs on back. This normally wouldn't be a problem, but the unit is designed for both direct recording and mic use, which is how I use it. I first thought, "No problem, I'll stick it in my rack (up high!), wire the TRS jacks into my patch bay, and leave two 3 ft XLR cables dangling to plug into when I want to use a mic.
Ah, but that doesn't work, because once you plug a cable into the TRS 1/4" jack, the XLR jack for that channel is disabled!
So ... the unit has to sit out somewhere so that the back is accessible. This could have been solved by either changing that XLR-shorting design or by putting the jacks on the front. Granted, it wouldn't look pretty having chords dangling from it in front of a rack, but the way it is now, if you want to use it for both mics and direct, it's either gotta sit out on a desk top somewhere and take up valuable real estate, or you've gotta crawl behind your rack every time you want to record direct.
Am I missing something? Does anyone have a solution to this?
Grrrr.
Grrrr.
