(Cheap) Preamp Suggestions?
  • Thread starter Thread starter KeithG
K
KeithG
I finally got the recording process down on my TASCAM DP-02CF and now I really understand why so many people say "trust me you'll need a preamp." My signal levels are always low when I"m bouncing and recording multiple tracks. Does anyone have any suggestions for an EXTREMELY low budget preamp ($250 and under)?
Sweet Jesus, you could buy several Presonis Tube Pre's, or ART's for that money...
I think in the used market (maybe new) you could find an ART ProChannel or an M-Audio Tampa. Both will do ya fine.
The ART gets a little dirtier (I swapped the tube in mine)
The Tampa is cleaner and has a good compressor.
my thots... :p
As my recent thread (link below) seemed to confirm, M-Audio's DMP3 pre (~ $150) receives generally good support from the good folks here. Search a bit to find many other related threads. Given the DAW you're working with, I wouldn't think you'd need to spend much more.
https://homerecording.com/bbs/showthread.php?t=284240
Id probubly go ahead and use the Tascam preamps before Id use the M-audio piece...I wouldnt think you would be gaining anything there...Id use something with coax outs if the unit has coax in....that way you can add a couple of mics you couldnt before.
If you are looking for a sonic improvement in pre's you should use the Line6 UX2...and they have a coax out at that same price point.
Another vote for the DMP3. The PreSonus crap is - well, crap. Same with most of the ART stuff also. The DMP3 is one of the only truly decent "amazingly inexpensive" pieces out there that's worth a hoot.
THAT SAID: Your preamp has very little to do with levels being low** when you're mixing tracks. Unless you're not using a preamp and you're trying to run a microphone into a line-level input...
** "Low" like -50dBFS - Not "maybe just a touch below normal" like -20dBFS.
The Tampa and DMP3 are good recommendations.
If you could save up to $299 you could get a Golden Age Projects PRE-73 which would be my first choice!
:cool:Another Vote For The M-Audio Tampa (If you can find one) I'll buy a DMP3 Too.
