![Mart[1001]](https://img.homerecording.com/avatars/m/92/92266.jpg?1726078035)
Mart[1001]
After playing with it some more, the only thing I'm missing is some sort of built-in track EQ. There isn't by chance anything in the works, is it?
Well personally, I love the 'reaEQ'...it's parametric...you can just keep adding bands/low cut/high cut etc...it normally uses around 0.5% of your Reapers CPU power, so say you're mixing ten tracks and you drop one on each, that's around 5% for all your EQ processing. It's my favourite EQ without a doubt.
By the way just incase you don't know...if you grab the mixer(top bar normally just below the rate slider), you can drag the mixer up which reveals all your plugs and sends and is alot easier than having to use the effects button.
I then just drop one rea EQ on my first track...then just drag it to all the others. Ok it's not quite the inbuilt track EQ you're talking about but try it...it does me just fine.
Mart.
ps..don't forget also, you can configure a template...so when you insert a new track, you could have it pop open with a rea EQ mounted...though I've never done this as I just drop one in from my favs folder or even easier as I say...I just drag one from the adjacent track.
