Innovations
Both are takes on a PZM.
First, The Disk Mic.
This would be a large plexiglass disk with a small high quality capsule (most likely electret) mounted in the center. It would be a boundary mic with the plexi disk acting as the boundary. In addition the disk would act to reflect sound back at the musician, possibly eliminating the need for monitors in many situations and thus helping reduce feedback and bleed as a result. This could be used for backup singers and also a good choice for brass, which tend to blow sound everwhere except back at the musician.
Second, The Piano Mic.
This would be a long black cloth belt, perhaps with some elastic to keep it snug. Along the back side of the belt would be three quality capsules (again most likely electret) all mixing into one output. Strap the belt around the lid of the piano and tada! The piano is miced across the whole range of keys with a single channel on the board. Moreover it could be used both for permanent installation (since the lid can be closed and a cover put on with the mic still attached) yet also easily tossed into a kit for remote recording (quick setup with no need for a mic stand). It also would solve the question of how do you install a PZM on the bottom of the lid of a piano without marring the finish.
Discuss...are they workable? Marketable?
