T
Triazic
Hi, I have a great big question, so I'll break it up into blocks to avoid a wall of text.
THE GOAL: To record drum cover videos to be uploaded to youtube.
THE PROBLEM: When recording into my computer, I get a gradual audio lag that builds up after maybe 3-3.5 minutes of recording. The problem with this is that when laying down the MP3 backing track, my drums will lag behind towards the end of the song despite me playing in time whilst recording.
How I tested this: I layed down the MP3 of a particular song in Track 1 of my music software. I then recorded said MP3 through my ipod, connected to my mixer, and then connected to the computer (have tried USB via mixer, or main mix out then using converters into mic or line in input on the soundcard) into Track 2, and lined up the start of this recording perfectly with the MP3 on Track 1. The recorded track, coming through the mixer, drops behind the MP3 about 3 minutes in by about half a beat, enough to make anyone's ears bleed. (note: this is not a sudden lag, but gradual; at 3 minutes it is painfully noticeable, though).
What I could do, but what I will not do:
a) Dilate the timing of my recordings such that they align with the MP3 track. I could do this, but I'm seeing that as a bandaid solution, and that in itself causes some issues; also, if I were to record, say, a 'how-to' or tut vid on drums without a known backing track, it would be near impossible to synch my stand-alone audio correctly with the independent video footage.
b) Install a PCI soundcard; the computer is not owned by me, and to open up the case would void the warranty.
c) Purchase another mixer, or excessively expensive equipment (over $200 AUD probably, I'd just dilate the timing before forking out that kind of money).
What I have tried, and thus what you cannot suggest
a) To try switching between using the 'line in' or 'microphone' jacks on my soundcard or using the USB capabilities of the mixer; I have tried all possible options of this sort, and all have had the lag to minimally varying degrees (all pretty bad).
b) Upgrading the REALTEK drivers (an error in installation and had to use a recovery point to fix), I have also tried ASIO drivers with both high, and low buffer rates; hardly any difference.
c) Altering sample rates (I have tried 44.1, 48, 96, no difference whatsoever).
THE EQUIPMENT:
1. A good, new computer (running Windows 7); has a lot of grunt, 4gb ram, quad processor ---> I could not see the computer or CPU itself being the cause of the problem, and it is out of the question to upgrade it anyway.
2. Alesis Multimix 8 USB (1.1, not 2.0). I know the mixer here is a likely cause of the problem; as 1.1 is probably struggling to keep up with 3-4 mins of data.
3. STOCK SOUND CARD (Realtek HD Audio)
4. Acoustica Mixcraft 5, and Ableton Live 8 (have used both with all types of inputs, ie line in, USB...). Both have equal lag.
3. Drum mics etc, not really important for this.
WHAT I AM THINKING OF AS A SOLUTION:
It seems to me that there are two potential weak links in the chain; when using the USB functionality of the Alesis Multimix; the mixer is the problem, as the mixer acts as the sound card (feel free to correct me on this if I'm wrong, this stuff is really confusing...). When using "main mix out" on the mixer, and plugging into the sound card; the sound card is at fault.
I'm not going to upgrade to a USB 2.0 mixer, because they are $800+ AUD... which is unthinkable.
Therefore, I have to do something with the sound card.
This is where some help would be nice
I've seen a youtube drum cover guy, who's got good quality explain his setup (here: YouTube - How I Record My Drum Set), and he uses an analogue mixer and runs it via RCA output (my mixer has this, also) into a Behringer U-Control UCA 202 (Allans Music + Billy Hyde - Shop : Behringer - USB Audio Interface - U-Control UCA202 ) and then into a freakin' laptop!
and then into Mixcraft 5 (same as what I have).
I'm wondering if this would also work for me too, as the U-CONTROL is well within my price range. I'm wondering though, why would this option be any better than using the Alesis Multimix 8's USB functionality, since both the Multimix and the U-CONTROL are both 1.1 and not 2.0 USB connections?
Is the sound card/interface built into the multimix really bad or something?
If your advice is against/an alternative to the U-CONTROL, keep in mind my low price-range, and also keep in mind that I already have a mixer, and have absolutely no need for an audio interface/sound card that has preamps, EQ, XLR slots, 16 million inputs etc. All I need is ONE input (I'll just plug my mixer in), and maybe a slot for headphones/output to speakers (even that is unnecessary though, to give you an idea of how little I actually need).
Thanks heaps in advance, sorry if some of the information I have provided is irrelevant, but I'm trying to give the deepest possible analysis of my situation possible so that you could provide sound advice.
Cheers all,
Oli.
THE EQUIPMENT:
and then into Mixcraft 5 (same as what I have). I'm wondering if this would also work for me too, as the U-CONTROL is well within my price range. I'm wondering though, why would this option be any better than using the Alesis Multimix 8's USB functionality, since both the Multimix and the U-CONTROL are both 1.1 and not 2.0 USB connections?
Cheers all,
Oli.
