Monkey Allen
Fork and spoon operator
My Mullards say made in Russia....is that just a deception?
Try the Tung-Sol 12AX7's.
Not too expensive and they make a noticeable difference.
A number of years ago I had a conversation with the head teach guy at ART about this same topic and posted it here or on Gearslutz (I bought one of very first GOLD MPAs released).GAH! You had to throw a 3rd tube into the mix didn't you!!! =D
While I appreciate your input studioguy, I really just need opinions on whether I should get the NOS Mullard AT7s or the new production AX7s (whether they are JJs, Mullards, Jans, Tung-Sols, etc will be a separate discussion).
Should I just give up on recording all together!?!?!![]()
Seriously though, should I not even bother with either of those Mullards, I was pretty well set on getting both until mamm rained on my parade. Are the Russian Mullards just as bad as the Chinese? Should I go with Tung-Sols? Aren't those gonna be just as cheap? Are they both really just as cheap as the stock tubes? Am I just as well off not replacing the tubes unless I can get NOS AX7s (a.k.a. spending at least 150 to replace both tubes so it seems).
Is an AT7 a bad idea (I still haven't gotten a straight answer on this one)?
I have two NOS Mullard CV4024-ECC81-12AT7's and one NOS RCA Blackplate which I use for guitar amps. Last night I put one of each in my MPA Gold to see how they'd sound. Both tubes sounded great, but the gain was too low. When the gain was high, so was the noise level.
