for what it's worth.
owned an mpa gold, loved it to pieces. stock tubes sounded great. swapped them out of course, experimented, the differences in sound AS LONG AS THE GAIN SPECS WERE THE SAME (!) were sooooo subtle. existent, but very very subtle. FAR more subtle than the fact that the mpa gold overall has a sound, regardless of the tubes being used, and that sound is golden. slightly middy in a very good way. changing the tubes with expensive NOS tubes rated with the same gain resulted in only very tiny differences and honestly in the recordings I used to test it with (and I did some visual analysis as well at the time) the changes were very very small, so much so that one would have a hard to impossible time picking them out in a single track of a mix. used for multiple tracks of course though you will gradually emphasise those subtle differences, but again it will be a very small amount.
And mostly - did it sound "better"? not really. not unless I pushed it into distortion of the tube circuit. THEN it did sound better with better tubes (which makes sense, similar to guitar amp overdrive with different tubes). but I generally don't use my preamps like that, so it ended up being a moot point.
I went back to stock tubes and was very very happy.
now of course, since most people are changing the gain structure when they swap tubes, they're hearing differences in the circuit and probably the level in general and it can change the tone in other ways since the mpa gold has lots of SS stuff through as well that interacts with the tube gain part. So people are definitely hearing stronger differences, and whether it's the tube or what the tube is doing to hte rest of the circuit, who cares? the tube changes the tone. I just always like to understand WHY
, which is why I posted this.
anyway, in the long run I only sold it due to financial crisis at one point, now I want an MPA GOLD again dammit LoL
PS - I'm borrowing an amazing ward beck 460 pre from a friend, incredible, based on a neve design but with differences. best pre I've used, and I used to own an API. But the mpa gold used to give me that magic as well. for it's price it's unbelievable, don't worry so much about tubes, get them if/when you can, the difference will be small but nice.
For now just make music with the thing man!
Cheers,
Don
