mshilarious
Banned
I have a bunch of small DIY projects I'm trying to finish up in the next few weeks, I'll post some of them here.
Here's something really basic that might encourage somebody--this is a 12VDC power supply in a 1u rack case. I used a commercial switching power supply, so it's not true DIY, but a good switching power supply is not really DIY.
The great thing about switching power supplies is better than 90% efficiency and excellent regulation. The downside is the potential for switching noise to leak into audio. This supply reads a dead 12.00V and 3.5mV of ripple. I haven't scoped it, but clearly this would need more filtration to be used in an audio circuit.
And that's OK, because it's in its own box, and any audio circuit really ought to have local regulation and filtration anyway.
In fact, I built this box as a power supply for the pipe organ I've been working on now for . . . uh . . . 18 months. I need a pretty good amount of power for it, this just switches the electromagnetic valves on and off, at 130mA a pop. This is a 15A supply, so in theory I could play 112 pipes at one time; I'd be happy with less than half that, as I only have about 230 pipes . . .
OK, back to the DIY: real simple, a hardwired AC plug (to avoid needing an IEC punch) into a switch (with integral 12VDC LED), a 4A circuit breaker (so I never have to replace the 15A fuse on the board--why would a 12VDC 15A supply have a 15A fuse at the 120VAC side
), into the power supply. 12VDC comes out into two Speakon connectors (for the pipe organ), but also two 2.5mm AC adaptor style jacks, one front and one back, so I can run random stuff off the same supply. Also, there is a fan to help cool the supply and the power LED that also run off the 12VDC supply.
Nice and simple, a $30 Mid Atlantic 1u box, and my trusty pair of step bits for drilling. The drilling was very ghetto, normally I print out a design template and tape it to the box to keep things lined up, but for my own stuff I don't care. You should see the box top where I drilled vent holes randomly!
If you don't already have a step bit, buy one tomorrow. I weep when I think of all the DIY years when I didn't have a step bit
), into the power supply. 12VDC comes out into two Speakon connectors (for the pipe organ), but also two 2.5mm AC adaptor style jacks, one front and one back, so I can run random stuff off the same supply. Also, there is a fan to help cool the supply and the power LED that also run off the 12VDC supply.Nice and simple, a $30 Mid Atlantic 1u box, and my trusty pair of step bits for drilling. The drilling was very ghetto, normally I print out a design template and tape it to the box to keep things lined up, but for my own stuff I don't care. You should see the box top where I drilled vent holes randomly!
