starbuck26
Hey fellas,
I was over at my practice space last night, and I started hearing a lot of radio signal coming through my amplifier. I went over to inspect it and went to flip the standby switch on. When I touched it I received quite a shock—the kind that makes you shake a bit and makes your tongue salivate immediately. I imagine I could have killed myself.
I went out to the hallway for a minute or two to make sure I wasn't going to die. I figured if I had a heart attack out there someone would see me collapse and call the ambulance. Turns out I was fine.
I went back in and used a drum stick to flip the amplifier off. Then I used the same drumstick to flip the tubes back on to drain the caps (which, I think is the way you're supposed to do it, no?)
I switched it to a different outlet and everything seems to be working fine. Now I'm terrified to hit the switch though. Anyone have any idea what could have happened? I assume it's the outlet, and I should yell at the company we rent from. I really have no understanding of where the problem can be.
What should I do?
What should I do?
