Enough clean gain??
  • Thread starter Thread starter mean_dorris
M
mean_dorris
Hey everyone,
I've got a question about ribbon microphones, I keep reading that they require a lot of preamp gain..
Is there enough clean gain in a typical compact mixing board? I've got a Mackie 1202VLZ, dated around '94 or '95. This will be my first mic (not counting my shure rs25 that i got for $25 new). I'm looking to spend about $150 or so, and I'm looking toward the Apex 215 or maybe the 210.
I'm an extreme newbie so far..
My gain knob goes to 20dB, there's also a trim knob which goes to 60 I think..
Thank you!
...most ribbons only just wake up at around 60+dB...70-75dB is more like it!...the AEA mic pre (designed for ribbon mics) tops out at a blazing 83dB!...:eek:
I've only got cheap ribbons (like sub $100), but my experience varies from the conventional wisdom some. With the stock transformers in them, they had about the same output as a SM57, believe it or not. I put better transformers in them, and the output went way down, but is still manageable for me (and they sound better, with more detail, wider response, all that nice stuff). I use a computer for mixing, etc., so I apply enough digital "gain" to bring the tracks up to the level of the other stuff, and it works well for me. Admittedly: 1) I usually record loud sources, like guitar amps or bagpipes with them, and 2) I've never worked with a "real" (i.e. high end) ribbon mic, though. The pres I generally use do have about 72db of gain, but I never go near that high - more like 40 to 50. But yes, I guess once I'm done boosting the hell out of the track digitally, I'm up in the 60-70s or sometimes even 80s.
But if you're working with an old mixer like that, does that tell us that you're staying in the analog-only world? If so, then you probably do want more gain.
(edit: I've been reading mshilarious's posts recently about cleanness of gain really meaning quietness of preamp overall -- with a noisy preamp, you just hear more of the noise when you turn up the gain -- I don't know if that's really relevant to your question, but it's interesting to think about)
Well, I'm running it into my computer sound card and using Cool Edit to capture.
I'm guessing I have 80dB to work with (60 + 20). I've tried cranking a channel to max output to see how much noise I get, and there is some fuzz, but it backs off pretty quickly if i turn the knob back around 1/10th of a turn..
I'm trying to produce a sound that is analog, I guess. I'm only using a computer because it's what I have, and it's easier to work with and edit than tapes (I think).. Though I really enjoy lo-fi recordings, band demo tapes, bootlegs, and stuff of similar quality.
Well, ribbon mics are nice to have - particularly for guitar amps and brassy hurtful sounding instruments like bagpipes. If you have the budget for one, I'd just pick it (or them) up -- you'll know soon enough whether you need to then get a new preamp or not :D - worst case, re-sale on ribbon mics isn't too bad I imagine, but you'll probably won't want to sell.
And I'm sure you heard the plentiful warnings about applying phantom power to a ribbon mic -- with XLR cables, I heard it's still pretty difficult to screw up, but if you have a TRS cable (the Tip-Ring-Sleeve quarter inch jack) in the chain and you're plugging or unplugging it with phantom power on, you'll send a brief burst of 48V up the wrong pin and blow that ribbon to kingdom come :D -- I've gotten in the habit of always checking that phantom power is off, even though I generally don't have TRS cables in the places where it could be dangerous.
edit: another *potential* weak spot is your sound card. Yours may be different, but most (and by that I mean all) of the "standard" sound cards I've worked with had pretty noisy line-ins.
Well I do have a habit of screwing stuff up..
It is a stock sound card that I'm using. My computer actually came with 2 sound cards, I'm using what appears to be the better of the 2. (The one with more inputs). Ever since I made the discovery that the mic input was mono, and the line-in was stereo, I haven't had any problems with noise..
Thanks for the advice!
...if you can save up just a bit more ($199), you can purchase a better sounding ribbon that is also "Phantom-Powered" so it will require much less gain and it will be impervious to accidental damage from phantom power bursts...check out Karma Audio's K-6...I've use it and it's much nicer than the Apex/Nady standard Chinese ribbon type:
http://karmaaudio.com/
If you're recording a loud source with a ribbon mic (drums, horns, loud guitars, loud vocals), you'll probably be fine. For a quieter source (quiet voice, flute, or distant miking of most instruments), you'll probably need a preamp with more clean gain, perhaps more than a typical inexpensive mixer. Ribbon mics produce a weaker signal, but it's still directly proportional to the level that reaches the mic.
Let's be clear on one thing: it's impossible to get a low noise floor when using a low-sensitivity mic on a quiet source. This is simply a matter of physics: it's impossible to build a preamp with much less than -130dBV noise. If you use a -56dBV/Pa mic on a 74dBSPL source, your signal level is -76dBV, and you will never have more than 54dB of dynamic range.
One possible way around this for a phantom-powered ribbon would be to use a high-ratio transformer into a circuit designed for that transformer in the mic. Combined with neodymium magnets, that approach could yield a low noise floor with a ribbon mic. But you need to evaluate a powered ribbon mic's noise level to see if it really results in an improvement, or just a perceived difference due to higher output level.
Would that not be the improvement I'd be looking for?
I intend to record a bunch of different things, small electric guitar amp, classical guitar (but not played classically :P), bongos, this magnus air organ that sounds like a sweet accordion, as well as my vocals. They range from whispery mellow stuff to pretty loud cracky grunge stuff.
I guess what I'm trying to say is, loud sources are as likely as quiet.
I'm comfortable doing mods as long as they're pretty simple. I don't imagine that swapping transformers is a terribly difficult task, but I don't think I'll venture into swapping out magnets.
I have no idea; you'll have to try the mic. It all depends on the execution of the circuit.
That's generally not possible; it's the ribbon motor itself. It's a matter of selecting the type of magnet you want in the first place.
...or to simplify...if it sounds good, it is good...(one man's "noise" is another man's "residual low level sound" or what I refer to as "I can't hear what you're talkin' about, but don't the music sound sweet?") ;)
