R
RAMI
Guest
Pure nonsense. I need to know the SECRET. Stop hiding the SECRET from us.All arguments aside, what you're asking is extremely subjective and not a one size fits all answer.
You say, "i wonder how to perfect the vocal?"
What is perfect for you? Are you trying to sound like someone else?? What do your vocals sound like now? What do you want them to sound like? Got any samples we can listen to?
You say, "i use vst plugins to tweak the vocal so its sounds ok"
Which ones?? There are thousands out there. I used to use the free Kjaerhaus classic series, but have since bought UAD stuff. But what works for me may not work for you. It's really subjective.
You say, "im interested to know about recording tricks"
Here it is, the definitive answer for perfect vocals by the Irish Pirate:
To record perfect vocals, start with an awesome vocalist and record that person in a pristine sound environment. (Most people would stop right there)
Use a really expensive mic. If it's got to be perfect, you've got to spend the big bucks. And you'll have to experiment with different mics to match the vocalist. If perfection can be compromised, then you can use a much cheaper mic, but that's not what you want.
Find the best matching pre-amp for the vocalist/mic combo. This is really important to maintain true fidelity. Again, you'll have to experiment to find the one that matches your vocalist.
If you're going into a computer, you'll need the best converter. I can only recommend Lavry. The absolute, undeniable best converters out there. If anyone tells you something different, then they don't know what they're talking about. PERIOD. I've got the black series, myself. (Oh, and if you're going to tape, I can't offer any advice. Sorry)
Once in the computer, you won't want to waste your money on free vst plugs because you won't achieve perfection. From here, which plugs to use becomes a hotly debated topic. No clear winners or obvious choices as each has it's flavor or coloring or lack of. Some people would advise not to even use plugs, but run through outboard equipment for optimal sound.
When you have your vocals recorded, you're going to need the best monitoring system (including room) to mix the vocals. This is a whole different subject. You wouldn't want to take a picture without looking through the viewfinder, and you wouldn't want to mix your perfect vocals without hearing what they truly sound like.
This might be a little tongue-in-cheek, but if you're going ask some vague questions, this is what you're going to get.
A successful pro recording engineer will have many years of experience and the right equipment to get really good vocals, maybe not perfect, but that's totally subjective. He'll know what mic to pull and hopefully will have a nice room to record in. You just can't find that kind of stuff in a forum post.
So when Shellshock tells you 'most people on this site will say the same shit "you have to listen and learn" or "its a trial and error process"blah blah blah' ... that's why. You just can't get a straight clear cut answer to such a question. ther perfect vocal is the holy grail and it's different for each person.
Good luck, have fun and...
Cheers,
(but serious about the Lavry stuff)
