X
xmortumx
Well this is my situation. I just bought an Echo Audiofire12 firewire interface and im thinking of purchasing a Tascam M-216 mixer to go along to record using my Daw nuendo.( I want the mixer to use the pres, and to monitor mix)
Now here is the deal, can i use the Tascam mixer Insert jack as outputs, then use that same insert return the signal from the daw so i can record, yet monitor my overall mix with the mixer and daw? Im mainly looking to Multitrack with the mixer yet i still want to use it along my DAW(nuendo) to monitor and mix... for example i want to use the board EQ, and at the same time use some Plug ins from my daw. Is that possible? will their be any latency issues?
Here how i plan on using the mixer along the audio interface(Correct me if something wont work)
Mixer----(with TRS Y cable) To AudioFire12 interface.
LOOK AT THE PICTURE!!
If you guys can help me clarify my situation please let me know of any suggestions.. or if i dont make sense because i really dont know about mixers along with DAW's.
thanks
thanks
