mattr
Resident moody teenager
I purchased a working Behringer ADA8000 off ebay around 3 weeks ago. When I got it I tested that it powered on and that each mic preamp worked, then racked it up and forgot about it.
Went to use it properly for the first time last night (for a live recording) and the fuse went. I changed the fuse for a new one of the same rating and it worked for 5 mins, then died again and refused to be resurrected again. It was connected to the same surge-protector/power-conditioner PDU as my Motu unit (which showed no signs of there being anything up with the power supply) so I don't think I was at fault with how I had it connected.
Obviously last night I was royally p*ssed off so I decided to leave it in case I just made things worse. This morning I cracked the case open and had a peek inside and there is nothing obviously burnt out (although one diode looks a bit suspicious and there's a faint lingering smell of burning electronics).
I've sent a polite email to the seller about the situation (but I haven't directly said I would like to return it). Do you think I can kick up a fuss and demand to return it for a refund, even though it failed under my use? How can I prove that I did nothing wrong?
Or do I have no basis for a complaint and so stuck with a £150 brick which I can prod with a soldering iron with hope? I'm really quite skint at the moment and so its very disheartening just to have something crap up on me like that.
