S
stupidfatnugly
anybody know any secrets to minimizing the amount of amp noise that gets recorded?
Noise Gate? do I have a plug-in of this in protools? I think so but I don't know how to use it.
what's a ground lift?
It could just be the way that amp is. Are you using a good signal cable going from the amp to your input? Your guitar cord can make a big difference too. You can also turn on the amp and go around turning lights on and off as well as other things to see if that makes a difference. Sometimes things like floresent lights, ceiling fans, etc can be causing the issue.the amp is 3 weeks old so I don't think it needs servicing.
my amp has a direct out and I'm just using that to record (no miking)
why do I get noise when I go direct?
a ground lift is one of those adapters that you use to plug a grounded 110V plug into a non-grounded wall socket. You just don't screw down the tab to the outlet cover.
Yes. But you also use it if you have a ground loop, which you might have.I would only use this if my receptacle didn't have a ground then, right?
dude you seem new to this. so DO NOT mess with mains wiring.. in the uk equipment without an earth is DEADLY.. with an earth it wont kill you (if your healthy) but will give you one hell of a suprise !!!
if your playing a guitar and get a shock you instantly grip tighter,you wont be able to let go... so your litrely toast !!!
try using a notch filter in your software (there should be presets for 50 and 60 cycle hums) with a gate....
It depends. There are noise gates and there are Hush-type units. Neither one will work for a ground loop. They are used to get rid of feedback and hiss that comes from having too much gain.I've been doing some reading and it seems like there is some kind of noise reduction unit. hard ware or software that I can buy
somebody said something about it on another post
what is it?
