J
johnbilben
Hey guys,
Well it seems as if the capstan belt on my 38 is shot. I found this out because when my machine is all spooled up with tape and i press play it just clicks as if i pressed stop. so i took the tape off and checked to see if the capstan shaft was spinning in play mode when i held the tension arms up and the capstan shaft was totally still, bringing to my attention that the belt is not doing what it needs to do. i know its not the motor the works the capstan because i DO hear a motor when i lift the tensions arms.
So, ANY help on replacing the capstan belt would be the best thing in the world. thanks alot
