Tascan DX 4-D Question
  • Thread starter Thread starter RevoStuder
R
RevoStuder
Greetings out there in recording-land! I have what may seem like a neophyte question to most of you, but its a legitimate one for a newbie such as myself. I have a ReVox A77 MK II that I really love, and I recently acquired a Tascam DX 4-D DBX Type I Noise Reduction unit that a guy gave me. Is there any way that I can use this with my ReVox? The ReVox obviously does not have the control signal input/output fitting as a Tascam recorder would have, but is there anyway to bypass this or rig it so that I can get the noise reduction capability of the DX 4-D unit without utilizing the control circuit?:confused:
Thanks all, I look forward to being a part of the forum!
RevoStuder :D
RevoStuder :D
You need to locate the control transistor(s) for each channel and short one of the outside legs to the center leg. Then encode and decode circuits remain on. Sorry, I can't tell you where they are on the board. I haven't been inside one of these for close to 20 years.
Thanks a Bunch!
Hey RRuskin, thank you so much for your reply. :cool: That makes perfect sense to me. I ordered a schematic that should be here in a day or two, and I'll give your suggestion a try!
Thanks again for the help! :D
RevoStuder
Tascam DX-4D Schematic
Hey RRuskin. Here's a copy of the Control Assembly section of the Tascam DX-4D. Is that Control Transistor you were mentioning in your previous reply in this schematic? :confused:
Thanks again for your help!
RevoStuder :D
RevoStuder :D
I honestly can't tell you. I just know that they are in the cicuit somewhere. Try following the path from the control plug to the 1st transistor you hit. Then short out with a clip lead. If all the status lights come on for that channel - you've found it
Thanks for the info RevoStuder!
Can you post the whole schematic for the DX-4? I want to buy one that I found that may or may not be working and would like to have the schmatic before I buy it.
Thanks
Alex
I think someone posted pics of how to do this in the analog forum
