Massive Master
www.massivemastering.com
With tape, it's a completely different story -
HOWEVER: (A) Digital has no inherent noise... (B) Tape decks followed the same "rules" as everything else -- 0dBVU was 0dBVU.
0dBVU is usually around -18dBFS... Although I understand some Apogee converters are calibrated to -12dBFS. Personally, my tracking converters are at -20dBFS (and I "pretend" they're at -24).
If you're only compressing the peaks, that's less "nasty" than hammering on the whole signal. But it's when those peaks are being compressed - That's when you really need to know how hard your preamp is running. And if it's catching those peaks, there's no real way to tell.
In 24-bit, anything above -20dBFS or so is a "good hot signal" -- I just prefer to keep that signal as pristine and clean as possible for as long as possible. If the peaks are bringing you over nominal, the compressor is allowing it to stay there more often. Never a good thing.
(EDIT) Didn't we just mention what a POS the Eureka was a few posts back?
