thebigcheese
"Hi, I'm in Delaware."
Well, I installed the control panel, but it says that it just uses the CoreAudio drivers. So yes, I'm using the default ones.
I haven't gotten it in a while, but there was one point where I got that greyed out screen and then every time I restarted, it would show up again. On like the 10th restart, it finally went away and hasn't showed up since. This was before I did any audio stuff on my computer, although I suppose Leopard was fairly new at the time, so it might have still been a bug in the OS (that got resolved, I assume). Lately it's just been the beach balls, which I assume are just a result of too much going on at once or something. I ran the IceClean program to clean some stuff up, so hopefully that will help. I still have nearly 18 GB of free space, so I can't imagine that it's just that the hard drive is too full (although I could stand to clean it up a bit).
It seems to work fine with Garage Band, so for now I'm assuming it's just the test version of Reaper being wonky. Having all these issues all the time has made me more wary about trying to get things like Wine to work when they don't the first time around. It just hung forever on it's registry lookup thing you're supposed to do (you have to install Darwine, right?).
On a somewhat related note, lately when I'm running on battery power, it will just shut down when the battery meter lists about 25 minutes left. Normally it would get down to 10 minutes and give me a warning first, but now it just shuts down completely and without warning. I don't know if it would help to just wipe the hard drive and to a clean install, but I'd rather not do that. I guess if I can use Time Machine to restore everything back, then it might be ok, but it'd still be a pain...
