I am not great with terminology so I hope I explain this question properly (I also only have a rudimentary understanding of my DAW)
I am using Logic Pro as my DAW and an Apogee Desktop Symphony as my audio interface. I am thinking of getting a Katana GO headphone guitar amp to use for practicing (normal use) but I would also like, on occasion, to connect it to Logic through my Apogee Desktop Symphony for recording purposes. I will state below how I think I might be able to do this and if I am wrong please correct me (I am not even sure if I can do this).
1) Plug the Katana Go into the guitar
2) I would use a standard 1/4 inch guitar cable to hook the "Phones Out" port on the GO to the "Instrument In" on the Apogee (where I would just normally plug my guitar into)
3) I would then open Logic and use the same Audio input channel (in my case channel 2) that I would normally record my guitar through which is labelled "Mic or Line". Then, I am assuming, I could record a guitar track normally in Logic and it would capture the audio that is being output from the Katana GO.
Is this correct or am I entirely missing the boat? I know the Katana Go can also be used as an audio interface itself but I would prefer to use the Apogee as the audio interface if at all possible. Thank you for any input you can provide.
