Not so a newbies questions but still...noise adding(!)
  • Thread starter Thread starter Anatolyz
A
Anatolyz
hi everyone!
im going to ask you kind of an unusual question ,saying the least:)
i want adding noise to my *.wav tracks i recorded,light hum or hiss...i'm not crazy ,i just need it to make the professional recording i made not so proffesional&more authentical...cause i have to send it as an audition cd :)
is it possible adding a constant noise (not too much) to the recordings?
thank you &sorry for the strange question...
AZ
Hi AZ,
There's a few different ways you can add hiss/crackles to your tracks. Depending on the software your using, there's some effects you can add which would do this. I used to use Cubase and once wanted to add crackles to a recording, it had 'vinyl effect' which you could put on to add crackles, pops and general vinyl sound.
If that fails, you could just record a vinyl playing or get a recording of noise and pop it on. End of the day, it doesn't have to be great quality as it's just general noise.
http://www.soundsnap.com/search/audio/vinyl/score Got plenty of crackling sounds to pop on to a recording.
Good luck,
thanx!
your idea is great,but anyway i need somehow to combine to waves to 1 wave file...thats i absolutely dont know how to do in fact:(
thanx dude
thanx dude
Combine the crackle with the .wav file you already have? Easily done in the software.. what software are you using?
and what exactly to do with it?
Wow Thanks!
And Can I Make Bouncing With That Program?or How?
Thanks!!!
the reaper...
this reaper program you gave me looks great but how to open there 2 waves and biunce them into 1 i dont really know:(...can you help me please ...
thank you!!
ohhhh....im starting to fifgure out the reaper but....
i found actualy how to play 2 wave's at the same time there...make it save as...(bounce)....but the file i get,windows player needs some codec for it...
how to make it to be a ussual common wav format...
Never used Reaper but i assume it will give you a choice of format when bouncing down no?
