Reason question (Fiev????)
  • Thread starter Thread starter Trumpspade
Trumpspade
Trumpspade
I'M BLESSED.......
What is the best way of transferring Reason projects from my laptop to my desktop and/or Vice Versa?
My advice is to make sure that both hard drives are the same letter (if you are using slave drives)...helps sounds come up faster.
I use a Usb hard drive sleeve with an internal hard drive inside it to transport sounds back and forth from the pc to the laptop. Works a hell of a lot faster than trying to use CDs or DVDs with sounds on it.
As long as Reason can find where the sounds that your project used are at, should be no problem at all. That's why I would recommend the portable hard drive so all of your sounds are there.
Anything else, send me a PM and I'll help you out Trizz.
Fiev
Fiev
I will...............
Thanks my brother!:D:cool::D:cool::D:cool::D
Btw, that THOR is a beast bro!
I'm gonna PM ya, but whatduyathink?
You can try saving the samples within rns file. It will make a larger file but if you ever misplace the hd you won't be without the sounds that open your file.
Will
Will
True, you could do that too. Really depends on what you're working with. If you just have a quick song you want to remix somewhere else, then I'd go with Will's suggestion. If you're wanting to make new tracks and have your full arsenal of refills, kits, and sounds, then I would go with mine. I thought you were wanting to basically transfer your studio which ever way so that option was best to do. If I'm wrong, then we still got you covered.
Fiev
Nah, I'ts my bad!
I should explain myself better. Both my laptop and my desktop is equipped equally. I travel alot, so I tend to take my laptop on the road. I just started getting into beats, so I create alot of stuff in the air or in a hotel. The projetcs that have potential, I prefer to transfer to my desktop, which is my main studio.
I used to piece my music together in Sonar in the air, and mix it once I got back home, it made travelling easier, but I was going through too many Cd's. I know it has to be easier to transfer a project from one computer to another that is using the same system...............
Nah, I'ts my bad!
Aiight, yeah with that situation, I would suggest my original method so you have your full kit available to you whenever, wherever...also. MAKE A COPY OF YOUR HARD DRIVE!!!! You can put all of your hard drive on a sizeable laptop drive and then get a 2.5 enclosure and have your whole kit on a small laptop hard drive which saves you room in your bags.
